Lost My Axle Tag.... | Ford Explorer Forums
dizzy6984
Lake Geneva Wisconsin
1993 XLT
So Yea i replaced my axle seals awhile ago, and forgot to but my axle tag back on, and i lost it, so know i want to know what ratio i got in there and i have no clue, ne one know what ratio they came with...
its a 93 4x4 X
Also what ratios can i fit in on the standard diff?
You can pop open the diff cover, and count the teeth on the ring, and then on the pinion. Divide the number of ring teeth, by pinion teeth = your gear ratio.
Here's a link with the same stuff I just said. It also says how to get a close number without taking off the cover: http://www.4lo.com/calc/gearring.htm
Shouldn't it be on the door? Also, you could spin the wheel one time and count how many times the driveshaft turns (an estimate atleast)
-Drew
What code do you have under axle on the driver door?
