lost | Ford Explorer Forums
lost
malyah monroe
1996 explorer
Hello everyone I am new to this site and very lost but I am very desperate to get any kind of help for the only ride I have right now I have a 1996 Ford explorer and while I was driving the truck it shut off and was over heated so I let it cool down and I noticed there was a leak in the radiator so I filled it back up and it started fine I went home added coolant and it still leaking I tried radiator stop leak and its still leaking very bad please help
You will have to replace whatever is leaking. Don't let it overheat and shut off again. You can blow head gaskets, crack heads, crack the block. If it hasn't already happened, you could also collapse the rings. I hope once the leak is fixed she's ok! Good luck!
