morlhug
- June 26, 2008
- San Angelo, TX
- 1984 Bronco II
I have a 1984 Bronco II that I purchased as a project/ daily driver. It runs just fine right now, it only has 100,000 miles on the 2.8 carburated (sp?) v-6. I want to put a bigger 6-cylinder in it though, as well as a new transmission, transfer case, and possibly axles, if I need to. I was thinking about the 4.0 out of either a Ranger or the Explorer. Transmission and transfer case I know know jack about so any advice on that would be spectacular. The axles: I don't know if I even need to change them, this is going to be a hunting truck, and it is going to get beat up, but it is also going to be a daily driver. As far as the suspension is concerned, I just want to put 30's on it and have them clear with reasonable travel room. Any info on engine swaps or advice on what I should use for tranny, transfer case, or if I should change the axles would be great, you can respond here or send me an e-mail at morlhug@aol.com. Also lockers? Do I need them? Most of my off-roading will be in rocky terrain.
