Brando
- March 13, 2003
- Gilbert, Arizona
- 01 Sport
01 Explorer sport 4x4 86K. Over the last few weeks i had a several incidents where i thought i was having a balance issues with a wheel...heard a loud "shimmy" and the truck wold start to shake a bit, i would slow down to a stop and it would go away. Reality was i felt different that a balance thing, i had eveything checked..all good. Then yesterday it did it again in a parking lot, same shake, not as bad, but a bit of metalic sound from underneath the drivers side. I stopped and it went away...i decided to get to the dealership...two blocks later it bef\gins again worse..loud BANG,pause,BANG,pause BANG i hit the brakes and came to a stop on the road. ( the BANG sounds like a 3 pound sledge hitting a solid piece of metal).
I started to creep forward and heard the bang again, a couple of feet, BANG again. I get off the main street and put it in reverse..same sound same timing. I start forward again and put it in neutral and coast a couple feet..same Bang, same timing.
NOW i stop, open the door lean over and peer under the truck and slowly let of the brake and creep forward BANG..i can see the rear drive shaft turning slowly and as it reaches a point , IT and the unit it is coimg out of( i think this is a transfer case , looks alluminum) seem to "load up" and rise up a bit, then BANG and the release a bit down.
WHAT is happening?
Anyone have a recommendation for a shop in the east Valley( Gilbert Chandler Mesa Arizona?)
Thanks !
WHAT is happening?
Thanks !
