SGl31
- January 22, 2018
- 1995 2wd Eddie Baur 6cyl
Vehicle is a 1995 Eddie Baur 6cyl 2wd.
Last week I noticed a loud humming or growling sound from the front passenger side of he truck when I get over about 30mph. It disappears when I apply the brakes and when I veer left. Gas mileage dropped from 18 to 15 and the truck felt like it was dragging. I put truck on stands and the passenger wheel had noticeable play at the 3 and 9 position. Driver side wheel did not. That and the sound going away when veering left made me think wheel bearing. When I pulled the spindle nut it was very loose. I spun it off by hand. I swapped the bearings out. I didn't replace the races as the ones in the rotor looked ok with no obvious damage. I put the hub back together and used a torque wrench to tighten the nut down. It went to about 85ft lbs but the rotor wouldn't spin so I backed off a 1/4 turn and reassembled everything. No more play in the wheel. The truck doesn't feel like its dragging any more but the sound is unchanged. The truck drives straight and doesn't pull to one side or the other. The sound still goes away if I turn the wheel left.
Not sure if it matters but the spindle nut is just a plain nut with no hole for the cotter pin. The chiltons book shows a castle nut.
Any help would be greatly appreciated.
