Dalmus
- August 26, 2009
- Milwaukee, WI
- '03 4.0L Flex; 190K Miles
Hi all,
Frequent reader, but a new poster. You folks have helped me figure out quite a few issues with my truck, from tire selection to the dreaded rear diff whine.
I've searched the forums, and don't know if I'm just not using the right phrase, but I haven't been able to find any references to my particular problem.... here goes!
I occasionally (4 -5 times per year) tow a pair of ATV's up north, about a 200 mile trek. The combined weight of the trailer and ATV's is about 2,400 pounds. I've got a factory class II receiver on a 6 cyl 4.0 so I should be good for 3,500 pounds, even if you include me, my dog, and my Stuff.
Intermittently, while towing this load at speeds above 40mph, there will be a loud "rumble" sound. Its akin to the frequency that a bad muffler produces in that it is very low-pitched, it drowns out normal radio and conversation. This noise can be present while traveling uphill, downhill, or on a level section of road. It doesn't seem to be related to acceleration; when I take my foot off the gas and coast, the sound does not diminish.
Any suggestions as to what might be causing this? Could this be a highly exaggerated chatter from the rear diff? Would a diff oil change possibly address this? Is this symptomatic of the larger ring and pinion failure?
Or am I on the completely wrong track?
Thanks for any advice!
Ryan
Ryan
