c33733
- January 11, 2014
- 2005 Explorer
Hi, First post here. Hope someone can help.
Have a 05 Explorer Eddie Bauer V8. 160K miles.
There is a very loud squeal under load. Sounds like a slipping belt, everyone that hears it at first says the belt needs to be replaced.
Bought car in October '13. Noise appeared about 5 weeks after purchasing car. Definitely was not there when bought.
It is definitely coming from the engine area, hard to tell exactly as it is only heard when driving and my head can only stick out the window so far.
It will not make the noise when stationary in neutral or park at any RPM or short on off rpm bursts.
It will make the noise under load at any speed, not at any specific RPM's but always around 2K 2.5K and above under load.
The noise gets higher pitched as the revs increase under mild to hard acceleration, but with gas off to cruise, goes away.
It does this from cold (doesn't change when hot).
I have checked the belt and bearings, but the noise is still there even with the belt completely removed, so that eliminates those.
Driven with air box open to eliminate bad seal.
Checked for vacuum leaks, found one and fixed.
Needed a coil pack replaced on #5 but the squeal was there before that went bad, so I guess just coincidence.
Replaced right front wheel bearing that hilariously wasn't noticeable on test drive and developed shorty after buying.
Checked for exhaust leaks.
No computer codes apart from random misfire and misfire #5 which was fixed with coil replacement.
There is a small hesitation from stand still and gas pedal is touchy from stop, but have been told that is normal.
That's about it. Makes me wonder why the previous owner sold it but honestly it seemed fine when I bought it. Bought it from a car dealer as is.
Thanks!
Cameron
Thanks!
Cameron
