Loud whine | Ford Explorer Forums
Loud whine
unabonked
Boston, MA
98Sport, 94XLT, 96Sport
Well my truck started whining when in idle a few days ago. It does this when accelerating sometimes, but this was during a dead stop and idling. It was going into the shop anyway so i told them about it. Turns out that my air intake was vibrating, and when combined with the movement of air, created a trumpet of my airbox.
Problem seemed to corrected itself after it got a little cooler. I was just wondering if anyone else had that same trobble.
Go Dead Link Removed to get the skinny. Replacing your IAC valve is the only real solution it seems.
-RB
This is my reply in the "e-mail about MAF" sticky thread . I cut and pasted it here :)
Seems everyone is getting beat up over this IAC filter , it likes to makes noise when it is hot outside .
It's not the air filter housing
I thought mine was doing the same thing and I tore the thing apart and checked everything . Nothing was wrong so I assumed the screen was loose and rattling . I bent the screen a little to put a bow in it so it wouldnt rattle . Still made the loud humming noise .
Someone said it might be the air filter on the Idle Air Control motor (on the side of your throttle body *looks like a beer can mounted sideways) ..It has a little black plastic cap and the cap is the air filter . When it becomes plugged for some reason the entire mess starts humming at idle . Mine got even worse once it idled for a few minutes and the engine compartment got real hot .
Pull the black cap real hard and it will pop off . You will think you busted it but it's the glue they attach it with breaking loose . Once you get it off , spray brake cleaner (or anything that won't damage plastic real easy) into the CENTER of the cap . You will need the little red extension that come with the can of brake cleaner to be able to spray down in it . You will see the dirt flow out of the outer edges of the filter . Continue flushing till the dirt runs clear . If you can blow air through the hole once it's clean it will speed up drying out the cleaner . If not let it dry a second then put it back on the IAC motor , just shove it back on . Fire the engine and let it idle ..... the hum will be gone . Of course you could replace the IAC itself .. mine was replaced and 10 months later it was making noise .
Ive thought about making a new filter out of tubing and a fuel filter (paper type) but never got around to it .
On a side note ,
If you remove the black filter and stick you finger over the port on the IAC that the filter covers ...........the humming will start :)
Also you don't want to drill holes or remove and leave the filter off because it filters air going into your IAC . Drillng or removing the filter will surely shorten the IAC motors life .
