Prerun4fun13
- May 16, 2015
- Pacifica CA
- 94 ford explorer
Ok so I have a:
94 ford explorer
4.0 Automatic trans, 4x4
I have a low idle (right around 500-600ish) and an intermittent miss that usually happens while I'm driving but will also happen sometimes at idle. I am coming up with codes 121, 522, 566, and 421 (i can't find anything on that one so I'm thinking i might have miscounted the blinking lights)
So parts I have replaced trying to fix the problem are as follows
MAF
Coil Pack
fuel filter
newish plugs (gonna change those this weekend)
and newish wires
The 121 code is "throttle position sensor out of test range"
Should I try replacing the TPS or is there something else related with this code that could cause this issue? Also what is the deal with the transmission codes? The tranny seems fine but it runs like crap.
Thanks again for any advice/ input. I am about to start banging my head against the wall with this truck.
94 ford explorer
MAF
Coil Pack
fuel filter
and newish wires
