happyjack87
- December 4, 2006
- Auburn, WA
- '97 XLT 4wd
I have done some searching on here and found some stuff that might help me I just want to clear something up. I have been for the past 5 months watching my rpm when sitting at lights. While sitting at a light, my x idles at around 450-500rpm, is this normal or is my x not running properly? I have been researching on here, like I said, for an answer and also reading my service manual. If anyone has any ideas what this might be please respond.
Just so those reading know what Im up against: I have checked the IAC valve and cleaned it, checked the resistance across the IAC, took off the PCV valve and shook it, cleaned the throttle body, added some injector fluid into my gas tank, checked the hoses I could see for holes that might be causing vacuum leaks, and some other minor things that I can't remember. Though non of these things helped or proved to be the problem.
Thanks for you help in advance.
