Lug Pattern Change | Ford Explorer Forums
Lug Pattern Change
94ranger3.0
Concord, NC
94 Ranger
Is it possible to use a wheel spacer to change the lug pattern to a larger pattern such as on the f150 or a ram 1500? if so where can i find such an item?
OR you an take your brakes and axles to a machine shop and have them re-drilled.
Ryan
is it possible to use a wheel spacer in that way? and if so where can u find one
i dont trust billet aluminum to all the torque and pounding you put through your wheels like spdrecr said i would re drill everything.:thumbsup:
