M5OD help?? | Ford Explorer Forums
M5OD help??
1badnevergo
Gulfport, Ms
'92 Mazda Navajo Lx 4.0
I have a 92 Mazda Navajo with the M5OD synchromesh 5 speed.
The problem I'm having is when I put it in 3rd I have to put the shifter almost into the 5th gear area and then once its in gear it looks as tho its in neutral on top of this when I try to shift to 5th I'm having to play with the throttle to get it to fall into gear.
This all started after my last offroad trip I went through a small mud hole and the truck popped out of first .
Anyone have this problem or now what this may be? I'm thinking it may be the synchronizers
Two Problems here...
Shifter needs to be re-built or replaced...rebuild is cheap, check eBay...
The synchros are what is making shifting harder...
Rebuild it...I did it...
Ryan
Got the problem resolved I replaced the none existent bushings on the shift ball not hard to do cost to fix $10 and 1 hour including drive time
