MAF Sensor Question | Ford Explorer Forums
MAF Sensor Question
Shamrock
South Bend
98 XLT
I have a 73mm MAF sensor from Explorer Express. They said it's for a 91-94 Explorer. Will it also work on a 95?
Thanks
Will it plug in to the connector on your '95? If so, I would give it a try. If it plugs in, then it would probably work since Ford probably used the same size injectors on the '91-94 and the '95. They are calibrated per injector size. The only problem you may run in to is the connector might not be the same. I know the MAF I bought for my '94 4.0L Ranger did not have the same connector as my '97 SOHC Explorer. I was hoping to try it out on my Explorer but ended up selling the MAF.
Im pretty sure it wont work, as they are calibrated per model. I would think that they would even need your calibration codes in order to sell you a MAS. What you could try though, is using your old sensor in the new larger MAS housing. I dont know if that would match up either though.
nick
