Main and Rod bearing question | Ford Explorer Forums
rlpete01
1998 Explorer Eddie Bauer
Putting main and rod bearings in a 98 4.0 SOHC and the Haynes manual is giving me oil clearance spec of:
rods
desired 0.0003 to 0.0024inch
allowable 0.0005 to 0.002 inch
mains
desired 0.0008 to 0.0015 inch
The part store only has plasti gage starting at 0.002 and larger. I have already found some incorrect information in this manual so I would like to see if anyone could verify these. And if they are correct what to use to check them if i can not get the proper size plasti gage.
two ranges
Advance Auto sells a plastigage equivalent with two ranges - red: .002 to .006 inches and green: .001 to .003 inches. You need the one with the smaller range.
I checked one of my main bearings and it was slightly less than .002 inches with more than 150,000 miles of wear. I think the tolerances listed in your Haynes manual are reasonable.
......... I think the tolerances listed in your Haynes manual are reasonable.
They are consistent with just about every Ford engine I recall checking specs on, always taken from Ford Shop Manuals.
Bearing clearances are usually preferred to be on the looser side for high-speed heavy duty use. Clearances for High-Performance engines are always on the looser side. imp
