maintenance manual | Ford Explorer Forums
maintenance manual
rjdelew
Hello everyone,I am living in Saudi Arabia and am in need of the service repair manual on PDF if someone has one.I have been unable to find one local or on ebay.I am hoping someone here can steer me in the right direction so I can buy one.
I have a few maintenance problem. One being what oil goes in the rear end.My vents cycle on and off the AC is still on but the vents just turn off.I also have to fix the cruise control and try and figure out how to give this suv a tuneup.I have a intermittent idle miss.Does someone have a breakdown for the vin numbers I need to know what model this suv is.
2004 or 2005 explorer
Wow dude. You don't ask for much.... lol
I am not aware of a service man on pdf. It's either paper or the service DVD disk. There used to be an internet site that had them all, but something happened to it.
You will find the oil question answered several times here by using the search function. You might need a suction gun to replace it.
I'm not sure what you mean about your AC problem. Do you mean blower, or are you really talking about how to turn the individual vents on and off?
An intermittent miss can come from several problems. I would make sure everything was tuned first, then look at possible vacuum leaks, then I would have it put on a real scan tool and look at the sensor data.
I'm not sure what you mean about model, either. Models, if I am right, are like Explorer, Expedition, Excursion. If its' an explorer, I bet your vin starts 1FMZU if it was made here-ish. Otherwise, I think there is a decoder somewhere here that can be found by some more searching. If someone else doesn't chime in, I will check back in a couple of days and go find my data.
-Shawn
