making a 4wd a 2wd | Ford Explorer Forums
making a 4wd a 2wd
shorty_2low
IN, spencer
1994 XLT 4x4
howdy!
i have a 1994 xlt 4dr and sadly its a 4wd :thumbdwn: so i wont to make it 2 wheel drive to get it on the ground ( maybe with air bags) but any way i wont to know what all suvs/trucks can i use to make the swap. EX. ranger, najho(s/p) or other ho-splorer, so if any one knows about this please help.....
Ps. are there any explorer junk yards that deal explorer parts that i could look up? or would the parts wieght to-much to ship with out an are and a leg?
why the double post? anyway, sell it and buy a 2wd one....... imho it would be cheaper in the long run
I would start with a set of aftermarket drop I-beams that will give you about 3" drop and still keep your alignment and suspension geometry right. With bags and fully dropped on the ground the tires are going to do / \ but a lot less so than if you had the stock I-beams. From what I've seen the I-beam mounts are the same between the 2wd and the 4wd. Contrary to popular belief the I-beams on the ranger are smaller than the I-beams on the explorer, from what I've seen the explorer front suspension is a cross of F150 and ranger stuff.
The radius arms should be the same between the Ranger and Explorer however the F150 ones have the shock mounts on top instead of the side. I haven't verified that they are the same between explorer and ranger so to be on the safe side I would just stick with explorer parts.
There are also subtle differences in the steering knuckles between the models. I'm still figuring out what will fit where but the explorer steering knuckles are setup to bolt the tierod ends on top of the steering arms and the ranger/F150 are setup to bolt them under the steering arms. Normally this wouldn't be a big deal but when I lowered my 93 I wanted to run the tie rod ends under the steering knuckles to reduce the angle of the steering links and help clear the sway bar however I discovered that the holes in the steering arms have a taper to them that looks a little like \/ as do the tie rod ends. I supposed they could be bashed in from the bottom but I would worry about having some slop in the steering system. Like I said I'm still trying to figure out what will work where.
Driveline wise you could just lose the front driveshaft once you pull the front axle off and leave the t-case in place.
I'm not sure about the springs or the spring mounts on the 4wd vs the 2wd.
As far as selling it to buy a 2wd goes, if you can find a good deal on a 2wd and can get decent cash for your 4wd then I would say go for it. Of course if you have a lot of money tied up in repairs and mods you might not want to get into a vehicle that you don't know the history on. You can also make a few dollars by selling the parts that you take off.
Keep an eye out for part-outs, it seems that every few months somebody is parting out a 1st gen that as been wrecked or just used up. Most of the time you can get some pretty good deals on the parts you need.
Good luck.
thanks....um the reson i dont sell it is there are no 2wd around and i would wont one just like my ho-splorer black with gray guts.
so you say just to get a broke down explorer from the junk yard?....what all do i need, is it from the brakes to the brakets the i-beams hang off of?
The brackets the I-beams hang off of should be the same.
You will need the I-beams (stock or dropped is your choice) radius arms, steering knuckles with the disc brakes and brake caliburs (not sure if the 2wd is the same calibur as the 4wd) You will also need all the various bolts, brackets and other crap that comes with it. I'm not sure on the springs yet. If you can, just gut a 2wd explorer or wait untill I gut my 92 in a few months then take all the parts off of my hands.
Tim
Tim
i can wait if you have what im looking for. how much would you charge me for the hole deal? and how would it be shiped?
if you would like to e-mail me at : shorty_2low@hotmail.com or i could e-mail you to talk about it.
thanks
Mark
i know that the 4x4 sports and the 4 doors used the same calipers... so probably, the 4x4 and 4x2s did also.....
