Master Window Switch Works, All Others Don't | Ford Explorer Forums
erichalvrsn
2005 XLS
I have an 2005 XLS explorer and recently the passenger window and both back window switches stopped working. Everything works from the master control switch and I checked the fuse box under the hood and everything looked good. Is there another fuse under the dash that could be the cause or does this sound more like a wiring issue?
I had a similar issue with 03 explorer limited. The windows other than drivers failed in series over a few months. It seemed illogical that the window motors would all fail so I decided to check connections. Turned out to be the molex type connector to the master window switch in the drivers door. Easy to access, check the connections. Re-seated mine and all function properly now.
