2manymustangs
- April 1, 2009
- St Louis MOOOO
- 2002 Sport Trac
2002 Explorer sport track 4.0 SOHC
Well, after a leisurely drive to Denver and back to St Louis I was planning my next oil change (have switched to Valvoline full synthetic).
I drove around for a few hours on Saturday putting around and to my surprise I came up with a flashing CHECK ENGINE light.
Codes are 304 and 316 if I remember correctly which comes up to Cyl 4 misfire.
The engine lopes at an idle and is acting the same way it did two years ago when the #6 cyl exhaust valve spring broke (right in the middle). Compression test yields little or no compression and I can feel a light pulse in/out when the engines runs and I hold my finger over the end of the compression tester hose.
Im pulling it apart tonight.
Any input on valve spring issues would be appreciated. It has been running great since the last valve spring issue about 40K miles ago. I dont tow much at all and the car gets driven very adult like...
Im at 150K miles presently...
