Measuring resistance in a spark plug wire | Ford Explorer Forums
jremington59
Watertown, NY
1997, 99 and 2000 5.0's
I have a skip in my 97 4.0 exp. I misted the wires with water and had an arc on one wire. I pulled the wire and checked the ohms and got a reading of 14.34K on my meter which registers from 0 to 20,000,000 ohms. The wire is a little over 2 foot.
I'm not real experienced with meters, but wouldn't that mean 14,340 ohms of resistance? Also, shouldn't a good wire be less than 4.0k ohms resistance per foot?
Resistance per foot
According to the article at the following link, MSD ignition helically wound wire has a resistance of 40 to 50 ohms per foot. I don't know if that is typical. I just measured one of my wires (about 14 inches long) and the resistance was 6.3Kohms. Your 14.3Kohms for 2 feet seems comparable.
MSD 8.5mm Super Conductor Spark Plug Wires 32559
Yep, normal resistance for stock wires is about 5-8K ohms per foot
of wire. I suspect the arcing was from a loose or broken terminal end.
A sparkplug will also have an internal resistance of about the same,
normally 5-6K ohms.
Are the wires original? Even if they aren't, if you have arcing, they should be replaced regardless of resistance.
You have 5 others to compare your readings with... but I suspect that its correct. Anyways, arching is an insulation problem not usual a conduction / resistance problem.
Thx everyone. I found the problem. A plug was cracked.
It's nice to know how to check the wires now though. When you take a reading, what does the k stand for in 14k ohms?
just like in other things (kilometer - km), its "short" for 1000.... and in your case 14 000 ohms.
