Spark plug wire findings on resistance...Helpful info inside | Ford Explorer Forums
EliteConcept
LaPorte, Indiana
04 Civic LX
Changed my plug wires today after 65,800 miles. Truck ran fine, got fairly decent MPG...around 18 MPG average. When i pulled all the plug wires off i put a multimeter on them to find the resistance, because i wanted to compare it with that of the new wires heres what i found, for reference by others if someone ever needs it or is just wondering...
Old Motorcraft wires using the numbering on the stock wires.
Plug Wire #1 - 12.62 K ohms
Plug Wire #2 - 11.25 k ohms
Plug wire #3 - 11.11 K ohms
Plug wire #4 - 7.43 K ohms
Plug wire #5 - 6.35 K ohms
Plug wire #6 - 5.30 K ohms
Brand New Autolite Pro Plugs
I defined the plug wire number by which plug i put it on.
Plug wire #1 - 6.86 K ohms
Plug wire #2 - 6.78 K ohms
Plug wire #3 - 5.93 K ohms
Plug wire #4 - 4.47 K ohms
Plug wire#5 - 4.26 K ohms
Plug wire #6 - 3.4K ohms
Maybe this will help some of you in the furture
ok just so i understand....resitance is bad so the less the better right? i know im slow =)
yeah, you want your wires to have as little as resistance as possible.
Also remember that the long the wire the greater its resistance gets.
EliteConcept, interesting comparison. That seems to confirm that spark plug wires do indeed wear out.....
Generally if a wire has more than 10ohms of resistance its time to replace them.
But the shorter wires that have lower initial resistance may never actually reach 10 k ohms
Runnin'OnEmpty
Are you mocking me?:p
I think the usual way of "defining" bad wires is a resistance/foot of wire. Chilton's lists it as greater than 7K ohms/foot. Since most spark plug wires are probably less than 1½ feet long, 10K ohms is probably a good rule of thumb. Do you have the lengths of those wires?
i didn't measure them but i can, i still have my old wires, and the new wires were about 3-5 inches longer than the stock ones
Runnin'OnEmpty
Are you mocking me?
No, no, no, Elite! I'd never mock you.:D Sorry if it sounded that way.....
My thoughts were that a lot of plugs and wires are replaced unnecessarily. The only way to know for sure is to do what you did, and take a resistance measurement. I've always heard that a ballpark figure is about 5K ohms per foot of wire. Any more than that and the wire is suspect.
I once had a Mustang that ran 125K miles on the same set of sparkplugs. I would clean them periodically; sharpen the electrodes and check the resistance. They always checked out at around 2-3K ohms resistance, if I remember correctly. Since the resistance was OK, I didn't see a reason to change them. They were Motorcraft's from the factory, and never missed a beat. (After 125K, the electrodes were starting to get pretty thin, however.) :eek:
heheh ok i was just checking? its sometimes hard to determine the context that ones statements should be read in... :)
Hey Elite,
Good post. Were the wires the same size were bigger?
I would honestly like to see a comparison of diffrent brands..
Anyone with me?
i thought they were 8mm but upon looking at the box to double check i didn't see that so i believe they were the same size.
