Memory Seats & Key Fob | Ford Explorer Forums
hitman17mk
Southwick, MA
2002 Eddie Bauer
now i recall hearing that each key fob would retain the drivers seatings, liek the memory seats and what not. is this true so that if user 1 sets the seat a certin way and saves it to #1 and user 2 saves there settings to #2 and each has there own key fob, whne the driver unlocks the doors depending on what key fob waqs used it will position the seat accordingly?
Yes, but you have to have the fob when you program the seat. Not sure but if remember you set the seat; hit the memory button; hit the keyfob; then the 1or2 button. Or it could be the other way, Mem, 1or2, then fob ?????
It does work on my '04.
jim.
Activating the memory seat feature
To activate this feature:
1. Position the seat to the position you desire.
2. Press the SET control on the
driver’s door panel.
3. Within 5 five seconds, press one
control on the remote transmitter
and then press the 1 or 2 control on
the driver’s door panel to which you
would like to associate with the seat
and Driver 1 or Driver 2 positions.
4. Repeat this procedure for another
remote transmitter if desired.
Deactivating the memory seat feature
To deactivate this feature:
1. Press the SET control on the driver’s door panel.
2. Within 5 five seconds, press any control on the remote transmitter
which you would like to deactivate and then press the SET control on
3. Repeat this procedure for another remote transmitter if desired.
