messed up | Ford Explorer Forums
messed up
Harbinger
pei
explorer 96 xlt
OK i in big trouble here
i thought the truck was sounding funny or rough while driving and a friend of mine suggested that i shift to neutral while coasting. I did that but wnen to far and now she will not turn o crank over, there was no clunking ,jolts etc, but shes dead in the water new starter was just put on, how bad did i mess up
you probably screwed up the flywheel so now the starter isnt grabbing it and is not able to crank/ turn over the engine.
great how bad is that to fix is it costly
is a automatic to if that makes any differents
Does the starter crank the engine, or does nothing happen when you turn the key?
nothing happens when i turn the key just clicks
Pull the starter, inspect & bench test. Inspect the flywheel.
Check the starter solenoid. Is the battery good?
ok what ive done so far is pulled starter inspected the flywheel,
starter spins out side the bell house,put it back just clicks, switch relay number 6, cranked crank pulley, 360 degrees, so engine is fine, checked fuel switch cut off, it up, tried in netruel and went thro the gears from park to 2 and back, tried by passing the start by using screw drive at the fender seliond, checked all cables and grounds,from battery, tighted battary connects so far just a click, im out of ideas
Did you test the starter when it was out by using jumper cables from the battery? If you did, I still say it is the fender solenoid, you need to use a jumper cable from the battery terminal to the starter cable.
If you take the starter to AUTO ZONE they test for free.
