C420sailor
- July 29, 2008
- Long Island, NY
- 98 XLT SOHC, 99 EB 5.0L
This question doesn't exactly pertain to Explorers, but I trust y'all more than anyone else, and I'm looking for generic troubleshooting wisdom that can benefit the gander...
5.4L 2V in a '98 Expedition
240,000mi, original fuel pump and injectors
Developed a miss under load. Changed the plugs (they were due). Still there. It now misses at idle. Hooked up forscan. P1000 code only. Forscan is detecting intermittent misses. It seems like when the truck is missing, STFT on bank 1 goes to around 20%. Then she'll smooth out and STFT1 drops to about 3%. Then she'll start missing again with the STFT back up. No rhyme or reason, and it's very binary---sudden and complete changes. Smooth as silk to shaking the truck and back. Both bank 1 oxygen sensors correlate with STFT. Bank 2 seems steady and solid as rock, with all data looking great.
So whatever this is, seems to be very isolated to bank 1, and sudden on/off/on/off. If it was both banks, I'd be looking really hard at vacuum leaks.
I'm wondering if an injector is on the fritz. If it was a coil (COP), wouldn't the O2 sensor go rich, and send STFT negative?
What's the best way to confirm and identify a bad injector? I was tempted to disconnect the injectors one at a time and see if the problem got worse or stayed the same, but something in the back of my mind was telling me that I would mess something up.
What do y'all think?
