Vapocalyptic
- July 9, 2014
- 97 Explorer xlt v6 sohc
Okay guys, heres the deal. I bought what is (turning out to be) a lemon of an explorer about a month ago. It has 170k, it's a 97 SOHC v6. It drove okay, I knew it needed work, but I did not anticipate this much stress. So, let's get what I've already done out of the way...
- Replaced bolt on EGR pressure feedback sensor
- Replaced all 6 spark plugs
- Replaced fuel filter
- Replaced air filter
- Replaced intake manifold gasket (cleared codes P303 and P305)
Now, I am left with code P0302 # 2. I took it to a mechanic, they did a diagnostic, checked the coil packs, plug wire, fuel injectors, they were good. Compression came at 160 PI, they swapped the aforementioned pack, wire and injector over to # 2, still misfiring. I was told the problem lies in the valvetrain, and they would need to pull the cover to continue further diagnostic, which would cost around 400 (not including parts and potential labor)
With the new intake manifold, it doesn't idle AS rough, but still pretty bad. I'm losing power at high speeds, it backfires at high speeds, and it takes longer than usual to get to freeway speeds.
I'm at my wits end - I have very little money and live hand over fist, I just do not have 400 dollars to identify the problem. I'm coming to you today to see if 1) Getting the valvecover off really costs 400.00+, 2) what could potentially be the problem and 3) Should I just sell the damn thing?!?
Thanks everybody.
Thanks everybody.
