charlieshick
- January 7, 2005
- Grand Rapids, Michigan
- '98 Explorer Sport
my 98 Explorer Sport was running great until about a week before Christmas when the thermostat went out. So, I replaced that and when I started it up to check it out it immediately started missing. That seemed a little odd since I had just repaired one problem and a new one started up immediately afterward.
Anyway, I replaced the spark plugs and wires, and still it misses and has a lot of spark knock. So, after that I took the coil into Auto Zone and had it checked, it's still handling a satisfactory 11 ohms. I don't know what to do next. An OBD II scan said that it's only missing on cylinder one. As far as how it's missing, the tachometer stays steady right where it should and my fuel mileage is just the same as it always was. It just shakes the truck pretty good. However, when I drive at a lower RPM for a while like in the city or anywhere below 55 m/h and then try to accelerate to highway speed it sputters and hesitates. This is remedied by turning off the OD and letting it run around 3500 for a while, then I turn the OD back on and it's relatively fine in that all it does is miss and not sputter.
In the end, I have no idea what to check next. I thought my plugs looked fine when I changed them but I'm going to check #1 again in the morning and I'm also going to check for coolant in the exhaust.
Does anyone have any suggestions?
