Brett F.
- November 17, 2004
- Upstate SC
- '93 4x4
Ok guys here is how I spent my Sunday. I installed the high flow intake filter on my 93 expolorer with the home made pvc adapter mod and after a couple of hours had it ready to go. ***It's just like the KKM*****
The vaccume hoses that went into the old intake box I just put screws in them. Had the negative battery connector off for the whole time to reset all the settings and mix settings.
Well I findished up cleaned up the tools and decided to drive it to check it out.
OMG it was pinging so badly I thought it would die on me.
So I go by Advance auto and pick up two cans of Sea Foam. I put one in the gas and one through the vaccume tree. Neighbors came over thinking house was on fire.
Drove it up the raid again. Still freaking pinging.
Ok what else could it be. So I talked with my neighbor and he said maybe I should figure out a way to connect the two hoses back into the system. So I removed the clips that hold the little diaphram thing in the air box and pulled it out. Then I punched two small holes in the top of the new filter and put the little thingy in the new intake and connected the hoses to it.
Drove it up the road and still *&*&$*& pinging. :fire:
I can't figure out what might cause it. The gas was fine before I put the mod in with no pinging so I figure it's got something to do with the high air flow.
I did clean the throttle body also with a toothbrush and some deep creep. If I were to check that top sensor on the top of the intake manifold what do I do to clean it or check it out?
That is the only other thing I can think of. You guys helped me to fix the 4WD and other mods to get better milage so I know you guys will have a lot of ideas.
Thanks for any help. It is drivable so I will leave it all on for now hopefully with your help it will stay.
Thanks in advance.
Thanks in advance.
