mod my 02 limited explorer swapping mustang part on it | Ford Explorer Forums
SergeJr
Ottawa
02 limited v8
hi im new to this forum site and i like some help to get a little more power on my v8 limited.
im a mustang guy i have 03 mach 1 all done up and lost of extra parts and have some friend with 2002 mustang v8 like to know what fits on it or what other year model mustang parts would fit my truck. its hard to find some part for the limited v8.
so this is what i like to do to it let me know if it will fit or what model mustang and year i can match the parts
.....best exhaust like the rumble
.....cold air intake
.....throttle body
.....fuel injectors and whats the stock size on it. whats the lph..
.....maf air sensor from a mustang will it fit.??
.....fuel pump is it the same as the mustang.??
.....coil packs are they the same as the mustang??
where can i find a handheld tuner for it. or can i custom tune the ecu on my truck.
Exhaust will be similar principles to that of a Mustang. Watch exhaust video clips of Mustangs, install that type of muffler on your Explorer.
Cold air intake - just search, I believe K&N makes a kit for the Explorer, and you can always build one yourself.
Throttle body - Not sure on this one, do a search and see if BBK offers one. Sometimes you can modify throttle bodies for better flow by cutting down the pivot shaft.
MAF - search the forum, someone will probably chime in
Fuel pump - search, but likely same style
Coil packs - likely the same but pointless to change, won't make any difference
Tuner - Search, SCT probably offers one
You don't need a different fuel pump unless you go with forced induction. The one your truck has will already support your truck NA.
