2 ohm amps are pretty much a standard, I'd be wary of running amps that are barely 4 ohm stable and can't handle at least a 2 ohm load. There are plenty of inexpensive brand name (Pioneer, Kenwood, JBL, MTX, etc.) amps that are in the $50-100 range and will easily handle a 2 ohm load.
If you just want to grab a cheap 4 ohm amp, use one amp to power 4 speakers and use the head unit to power the other 4.
Wiring 4 ohm speakers in series will produce an 8 ohm load, effectively reducing the power from the amp by half, and reducing even more with additional speakers. Most car audio amps aren't rated at such loads, and will often put out quite a bit less than half the rated 4 ohm power.
