Last weekend I finally installed some new parts. The same time that I was changing the oil (and that crappy ol' Fram Filter!), I put in new Bosch Platinum plugs (Not, however, the +4s), Splitfire wires, and the K&N filter. I expected that any improvement would be somewhat subtle, since my truck is a '96 and was running fine beforehand. There is a difference now, and it is good. But, as I expected, is not spectacular. The engine does run a bit smoother. There is a definite difference in power, which I feel mostly when going uphill. It seems to be able to hang on to its speed a little better now. There hasn't been a whole lot of change in the sound, but I did not remove the upstream portion of the filter housing as I would like to.
The bottom line is that I do recommend these upgrades to anyone, especially if you need to replace these components anyway. But unless your truck was running poorly before the mods, don't expect a super-fantastic performance improvement. My truck with these mod's is still a dog compared to my dad's SOHC...
Next, I would like to replace the exhaust with some sort of performance system, but I am not going to do that until this set rusts off... Dead Link Removed
JGB
Ontario Canada(!)
JGB
Ontario Canada(!)
