A recap of my most intense moments off-road
I need to thank Tom Davis, and Brian Kennedy and the others who helped extricate the "Great Pumpkin" from it's nearly fatal predicament!!
I was taking Collin's friend Winter for a ride letting him check out the Pumpkin's performance when I decided to follow Brian Kennedy up a cool looking hill. I should have known by the look on Brian's face that this was no ordinary trail. Brian was on the top of the ridge cambered down hill and there were lots of little rocks tumbling down the slope from under his tires. He commented on the narrowness of the trail and I thought I would try it, but stay farther to the right than he did when I got to the top. So I climb the hill with my lockers on, the hill has a sharp left turn at the top so I bear to the right a little as I give it some throttle. Suddenly the front right tire starts to climb the outside edge of the trail and the rear left tire starts to slide down the slope. I disengaged the locker, turned a little to the left to try and level the truck out and slowly let the clutch out one more time. Once again the rear end slides, this time slightly off the trail. The front end didn't steer down off the edge like I had hoped and now we were even more off camber.
Well that was it. We were stuck. Winter, was like "this is bad, we're in a bad spot" I knew he was right, but I just didn't talk about it. I called for Tom Davis to assist us with a winch. First Tom took his truck up the other side of the trail, and realized that he couldn't do much good from there. So he backed down and ran his winch line up the hill perpindicular to our truck. It was about then that I heard someone say they needed a tow strap, I just happened to have mine right behind the drivers seat so I reached back grabbed it and fed it out to Brian Kennedy. Brian, being a California Highway Patrol Officer knew just what to do to keep Winter and I calm and to kep our spirits up he said "Don't worry guys, I'm an EMT, I've got all my gear down in the truck, and if you guys roll I can get an Air Evac team out here in no time" I'm like THANKS Brian, just what we wanted to hear as we are precariously perched in the Explorer which is groaning and creaking just sitting still. I knew Brian was just using sarcastic humor, but it wasn't helping while we were stuck in the truck!!
The cable and tow strap were finally preparred after what seemed like forever and they attached it to the nerf bar. Tom tightened the cable enough to secure the truck and we started to drive forward as he pulled from the side. This worked great and after a couple pulls we were back to a level spot on top of the hill!
Everyone said, I was really quiet while this was all going on, I had a bunch of stuff going through my mind and was preparing for the worst. While I was stuck up there I kept the engine running and the transmission in gear, which of course meant I had to be mashing the brake and clutch pedal the whole time. The brake was easy to hold since my knee was bent, but my leg on the clutch started shaking since it was stretched practically straight out and the Center Force Dual Friction clutch takes more pressure to disengage, so I was literally getting "weak in the knee". My plan was that if the truck suddenly broke loose I would attempt to steer the front end down hill while giving it some gas to straighten it out. I had hoped if I was able to do this I would have been able to stop the truck mid-hill, before we crashed to the bottom, you see there was a long steep, loose slope leading to a verticle fall of about 30 feet!
Thanks again to everyone who helped out your team work payed off BIG TIME. And thanks to Brian Kennedy for trying to keep it light, but next time wait until the strap is ON the truck before you start in with the morbid humor
