ptf18
- June 5, 2012
- 2002 Sport Trac
Fellows. Found the rear end pinion seal leaking in the '02 S/T. While I'm going to change the fluid/oil I thought it best to replace the seal.
I want to use Motorcraft parts and need to know what the current p/n is. I "think" its BR3Z4676A.
The differential is a 8.8 NON- Limited Slip unit. Its a "straight" axle or that's what I call it. Not an independent unit.
I'm "thinking" that all the "straight" axle equipt S/T's use the same size seal.....
Thanks.
ptf18
Thanks.
ptf18
