It sounds like you have worked on quite a few mild 302 based engines with less money in them than a stock LS# engine. That is not a fair comparison. If an LS# engine costs $5000 or more new, or $3000ish used plus new parts, than it's only fair to spend $4000-$6000, or more to equal the costs of an LS# engine.
My 347 cost around $4500, complete, fully dressed. It is worth 400hp just like it is, and a very mild boost will make it strong enough for most comparisons. But that's still less money than an LS# engine, plus the stock block limits, so be fair and also include a Dart block. Right there you have a block that can handle any power, so stop mentioning weak blocks. Never use a stock 302 block for serious power.
To compare a strong 302 based engine to a strong LS# engine, spend the same $6000 or so on each. I'll take the Ford engine, it's smaller and lighter and will beat the Chevy. Don't use junk heads or OTS cams, or small intakes. Get the good stuff, the big stuff, the custom cam and Dart block, and then spank the Chevy.
I'll keep my Ford engine in my Ford body, and beat the Chevy engine in whatever you stick it in. Regards,
Don I have been in the Ford performance scene, both pushrod Windsor and OHC Modular for many years now. I have also been into the GM LSx engines for a while now too. With that said, it would be hard to say that I am brand loyal because I am not. But your post here that I am quoting seems to ooze of it.
First and foremost, there is no need to buy a brand new LSx engine because you can find plenty of them in used condition for only a few grand fully dressed and in amazing shape. ****, take a great condition LS2/L76 STOCK alum shortblock for around $1,200-$1,400, add a set of ported L92 (LS3 heads) for just over a grand, throw a FAST intake on it for around a grand, and a cam for around $600, and other BS parts like ARP fasteners & studs and whatnot for another $400 and you will be making WELL over 500+hp at the tires with a combo not even breaking a sweat and with the weight savings of an aluminum block to boot. All for less than $4,400. Hell if you wanted to save even more money then you could just get a used full longblock pullout LS1 for about 2 grand, throw a cam in it and be making over 400rwhp for less than $2,500.
Now lets talk about more serious power. Lets say you want to make 650-700rwhp. Well to do that in a Ford Windsor based 302 combo you will HAVE TO have an aftermarket R block (or other comparable block) with a fully built bottom end to handle that kind of power. PERIOD! Meanwhile Stock longblock LS2's, LS3's, and L76's are handling that sort of power all day long in BONE STOCK form with just a connecting rod bolt upgrade and head studs. So lets see here....Spend almost $5,000 on an engine that needed to be built to handle 650-700rwhp or spend about $3,000 for one that can handle it in stock form. And that is just starting out for those engines considering they hold that sort of power in unbuilt form. Put a little more money into them and they get nasty REAL quick.
Now once you plan on going past 1,000hp then the pricepoints to build both engines get a bit closer because now EVERYTHING has changed to the aftermarket with both Ford Windsor 302 based engine and the GM LSx engine except that the GM LSx still retains its stock engine block. Still, the 1,000+ hp comparison doesn't apply to 99.999% of people out there so can you really consider it a valid comparison here? Most would agree that it would not be.
Don you are a good guy, I have always liked you since I have been a member on here, and you sure as heck aren't a newby to performance vehicles. But in this particular subject you just don't have the knowledge-base to make any accurate comparisons here. You will notice that in my post I stated horsepower figures and dollar amounts to achieve those figures. I didn't see you specify anything like that in your post besides mentioning that you spent $4500 on your 347 and it should make around 400hp (and please tell me that 400hp figure you stated is at the tires and not a flywheel figure). This is probably because I am operating off of firsthand knowledge of the Ford 302 Windsor based combos and GM LSx combos I have built in the past, not just brand loyalty.
I pursue whatever approach nets me the most horsepower per dollar spent. If the Ford Windsor engine did it then I would be touting the Ford engine in this thread. But the simple fact is that when going after any horsepower between 400rwhp and 800rwhp the GM LSx is probably going to come out on top and most likely by a fair hp and price margin too. The GM LSx is not the best engine out there but in this particular comparison it does come out ahead.
Ford has long since the 60's made the best heads stock, with the aftermarket stuff, those are still better than any Chevy garbage. I'll take my high port heads or my Cleveland heads and laugh at your modern pushrod junk.
Some flow numbers at given valve lift heights and bore sizes would be good here. Please post.
