My 07 v8 limited sport trac back window problem | Ford Explorer Forums
JBoone
Alberta
07 st limited
the back window on my 2007 sport trac limited v8 wont roll down,
i have located all the fuses i can see that deal with this and they appear to still be good.
the moonroof is still working which shares a fuse with the window
tryed to look it up with no luck on any 2nd gen st back window problems?
Assuming its not just frozen shut due to weather conditions you're going to have to start the fun process of finding an electrical issue.
Grab a multimeter & see if there is power at the switch, if there is then you know you didn't miss a fuse and that the issue lays further down the line.
Next check for power at the window motor. If you have power there then you need a new motor. If not the problem lies somewhere between the switch & the motor and that will require a lot of disassembly of the interior to locate the poor ground or broken wire that's causing the issue.
Good luck :)
