My 1996 Aerostar needs help. | Ford Explorer Forums
96Aerostar
Louisville, Ky
1996 Ford Aerostar
I reside in Louisville, Ky and my sister bought this van in '96 and finally got herself the new Lincoln MKT and I inherited the van. No car payment is much appreciated.
Need your collective knowledge of thermostat replacement on a '96 Aerostar conversion van. The back heats up nicely but the front is cold no matter the setting. Also having problem with the plastic button that I guess push an actuator in the door to raise and lower the window. Are there replacement ones, buttons I mean. One is cracked and after much fidgeting I can get it to work but it is extremely aggravating.
Thanks for any info and advice you may send my way! B.K.
Welcome to this forum! I've moved your thread into the Aerostar section. It sounds like a problem with the heater control valve since you have heat in the rear of the van. Autozone sells those window switches.
Thanks for the valuable info
I appreciate your help! Definitely am not a mechanic.....have a great rest of your weekend!
