My 1999 Explorer is overheating. | Ford Explorer Forums
darrelbaird
billings, montana
2000 xls
i am buying a 1999 explorer limited, 5.0L that has a overheating problem. there is no water in the oil, but water is getting into the no.1 cylinder, fouling the plug, and in the end causing the engine to overheat. the overheating originally started when the radiator blew and the car overheated. could use some suggestions on what is needed to fix this problem. i will be doing the work myself and am fimiliar with the workings.
Welcome to the forum.
If water is getting in to the cylinder then you may have a headgasket problem.
