Gabriels Rage
- July 13, 2009
- Washington State
- '92 4x4 XLT
Wow! Thanks a lot Justin and Sewerat!
I've been a little busy so I have not had the time to make it on here... However, I did do an oil change (obviously put in a new oil filter also). That stuff was so black, it was bad. Thankfully though, there was no water or rust. Just lovely old oil. I also tested the radiator fluid and it came up with two balls, meaning that it was at +5. Woopie, probably does not help anything but I thought I would check anyways.
The next morning I took it for a drive around the block to see if it made any difference. Haha, nope... I took it up a hill this time and it started heating so rapidly it was almost frightening. By the time we got around the corner and made it to the top of the hill I threw it in neutral and coast up until I made it to my coldesac. Parked it and let it run for a minute, as the gauge was starting to drop slowly. In the mean time I stepped outside and it smelt a little bad and then I see radiator fluid pouring out. Killed it, then popped the hood and let it cool well I watched it flow out the radiator cap.
Tonight I finally made it to the parts store to pick up a new one (just a 13 lbs). Tomorrow morning I'm hoping to put that on and take off the belt and check the fan clutch and the water pump.
I'm thinking it might be the fan (along with the cap), as it would make sense to me that it is slipping and can't cool the engine fast enough as it is parked.
I'll check tomorrow hopefully, and probably fire it up again. If it starts to get hot still even with the new cap, then I'll just kill it and wait until Wednesday (or later depending on this heat wave) when I'll have more time to actually drain it and try the water cleaning thing.
Another thing I noticed, is even though its a new radiator it has several bent fins (rays, whatever you want to call them) along with smashed (huge) bugs in them... I think if I drain all that fluid out, then I might as well take it off and clean it and straighten it...
I'll try to update tomorrow to let you all know what happens with the new cap.
Oh, and one other thing I forgot to mention. The truck has 250 thousand miles on it, and most of the original parts.
Thanks again!
~Gabe :roll:
Thanks again!
~Gabe :roll:
