marragtop
- April 14, 2001
- balt, md
- 91, 92, 95, and 2000 xlts
The inertia switch is over on the floor in front passenger area by the firewall. You'll need to pull the carpet back a bit to get to it. Make sure that the electrical plug on the bottom of it is tight. When it doesn't start, you need to listen for the fuel pump priming for a second or two, when you turn the key to the ON position, but don't crank it. If you don't hear the pump run, then it's a fuel delivery problem. Also, when it won't start, try banging (or maybe kicking) the fuel tank. If it then starts, then that's an indication that it could be an intermittent fuel pump problem.
