99MERC
- December 12, 2005
- OHIO
- 99 Merc.Mount. AWD V8
I just noticed the other day my 99 Mercury Mountaineer leans on the drivers front side by almost 1" ! I checked all the air pressure in the tires and measured from several locations to verify,fender down to ground, A arm down to ground,shock mounts length. Every time about 1 " diff. between the two front sides. the back of the truck is perfect,but in the same sense it doesn't make sense. if the back is equal and the front isnt wouldn't that cause a high side in the rear too?
So I replaced all the shocks, sway bar ends. and still the darn thing leans too the front drivers.SOOO I adjusted the torsion bars ALL THE WAY UP as far as they would go and re measured, you guess it.. same difference. Higher but 1" off so I droped it back down and now I'm just getting ticked off. I went ahead and put a shackle lift on the rear to help the rear leafs abit and still have the lean and out of ideas. The tires are wearing perfect I checked the tread, it tracks straight when driving.... I need some advice on what else to look at!! Could I have a weak torsion bar? I tried to adjust just the drivers side torsion bar and make up the difference but it still raised the pass. side too making it closer to even but still a half inch off and a springy,tough left front. I'm out of ideas really! ANY ADVICE PLEASE!
Info:
99 STOCK Mercury Mountianeer
5.0L V8
ALL options but self leveling suspension.
solid rear axle
stock tires and rims
Info:
5.0L V8
solid rear axle
