My engine codes | Ford Explorer Forums
My engine codes
ruzztec
McCreary County,KY
92 XLT 4.0/99 XLT 4.0
KOEO
11
CM
14
41
63
66
KOER
21
41
I lookded up what they mean but I dont know what parts its talking about, ex 41-No Hego switching detected always lean (right side)----What is that?
That means a non operating Oxygen Sensor. Could be bad, could be shorted. Check the wiring and if it looks ok replace then sensor.
Thanks Glacier991 how do you get that? Ill check it right now but as far as in the later in life how did you know from that it was the O2? O and how did it turn out for you on that car you had getting hot and starting some times and not at others?
HEGO = Heated Exhaust Gas Oxygen (sensor). The computer uses the sensor as part of a closed loop feedback circuit to continually adjust the mixture by varying the pulse width of the injectors. The perfect air/fuel ratio of 14.7 to 1 is represented by a feedback voltage of .445 volts. In actuality the target is constantly moving, and if you wtch the voltages from an Oxygen sensor, it will vary from .1V or so up to about .8V "crossing over" the ideal .445v about 6 - 10 times a minute. When it never crosses over, or crosses over hardly at all, it will throw a code. In your case not at all meant code 41.
The "heated" is something added to O2 sensors early on in their existence because it takes them a while to become operational. The heater in the O2 sensor speeds up that process. Until they are operational, the car is basically feeding fuel based on tabular values in a lookup chart in the computer. Once the O2 sensors come alive, it switches over to closed loop operation, which is much better for emissions and fuel economy.
Hope that helps.
And no, I'm no closer to a definitive diagnosis on my Sable.. I have replaced the fuel filter, and will replace the relay, and carry the fuel pressure tester with me, so if it happens again I can isolate the problem as either fuel or electrical.
Yes sir the o2 sensor was firmly mounted yet the elec. was barly on it. Only one of four wires still connected. Thanks for the info. Good lucky with that Sable. I am of no use to you on that matter but i hope for you the best. Thanks agin Glacier991
