old mechanic
- November 23, 2003
- R.I.
- 92 xlt
And possible fix needed for what my Ex failed.
reading limit pass-fail
HC- Grams per mile- 00.59 02.40 pass
CO- '' " " 009.66 060.00 pass
NOx-" " " 04.17 03.00 FAIL
CO2 " " " 336.84 N/A N/A
As you can see the NOx failed. I don't know whats up with the CO2 reading also.
I would like to narrow it down as close as possible if possible.
I changed the oil and filter two weeks before the test and put some complete fuel system cleaner in at the same time. I put new Motorcraft platinum plugs in about 5 days before test removing battery cable while doing work. Plugs gaped at .0054 Seems to be running pretty good except for a very very little rough idle.
I was going to replace the o2 sensor and clean the MAF but I didn't because I thought it was running good enough to pass.
Thanks, old mechanic.
