My suspension plan is it worth it? | Ford Explorer Forums
wbandyjr
Ma
1997 Mountaineer
I have a 97 Mounty and i am going to put on 4 new ranchoo 5000 shocks and have the swaybar bushings replaced.,After that i am having supersprings installed and that will bring it up an inch.When i add these do i need to lift the front too? I put on p235/75/15 tires..I just want to gain 2 or 3 inches.
the shocks and the bushings will greatly improve the ride..... the supersprings i have never heard of and am assuming they are rear lift springs? you may want to look into torsion twist and warrior shackles if you want a mild lift of no more than 2" for your truck..... the stock tire size is fine if you dont care to upgrade now, although with 2" of lift, 31s would probably fit.....
$50 dollas from 4wheelparts.com or desertrat.com. But you'd have to call either of them to order. They're not listed on their websites.
The superspring things wont work. they are a helper leaf for a soa vehical. All stock explorers are sua.
I hope they do something i have allready purchased them..I hunted down a couple people who had used them.They said they liked them and the truck felt more in control
