strizzlow20
- January 28, 2010
- Sebastian, FL
- 1998 Explorer 4X4 SOHC
Alright here is what I have done so far. I replaced the upper Control Arm, New camber bolt set and lower ball joint. I also replaced the bearing as well. At 40 mph dead I hear a hum and it goes away at 55 mph. I changed the bearing on the driver side thinking it would fix the problem which it didnt. Do I just need to replace all of the bearings??? Is this rubbing noise while stationary from the new Control Arm bushings? I am dreading replacing the rear because I don't have much of a walk through to go by. The front bearings were a breeze. Any advice would be great. Thanks.
P.S. I also have to replace the sway bar links as well so Im not sure if that would cause any of these symptoms.
