Name of a part? | Ford Explorer Forums
Name of a part?
Jash006
Hooks, TX
2004 Ford Explorer XLT
I got a 2004 Ford Explorer XLT 4.0L V6 Flex Fuel. Does this motor even have a DPFE sensor or is it packed with other parts like the egr silonoid? A part number or general name would be a great help. Also I was looking into putting a flowmaster 40 or 50 series muffler on. Which sounds best for overall tone. Don't want to sound like a bumble bee with roid rage.
All things are possible through CHRIST!
Welcome aboard! :salute:
You should have a DPFE Sensor:
Location with V6:
picture.php
Here is a picture of mine, V6:
picture.php
How do you know you need to replace the DPFE Sensor? Did you get the codes read? If not, I would get them read, local parts stores like AutoZone, etc., should do it for nothing. Once you get the code(s) then post up here. That way any help or advice can be pinpointed to your issue.
Hope this helps out!!! :biggthump
Thanks. I had code for improper flow to egr. Seafoamed it. Still showed the code. Replaced egr and code came back after I reset the computer. Then I learned about the dpfe sensor. thanks again man!
No problem. :thumbsup:
Be sure to let us know how you make out.
