Need 1997 XLT 4.0 OHV M5OD wiring diagram. (starting circuit) | Ford Explorer Forums
freak
Location
Northwest Ohio
Pemberville
2000, Explorer XLS
I've got a tough one. No crank. If I put power on the starter relay the starter works. I've tested the circuit through the clutch switch right to the firewall. Pink wire on the top connector has 12v when key is in start. It loses it somewhere after the firewall connector and the relay. That pink wire doesn't go straight to the relay, it turns red/gray at some point. Would love to see all where it goes.
nvm found it
