bullinerfamily
- February 25, 2006
- Murray,KY
- 92 xlt 4dr
Problem Fixed!!!! Rag-Joint / Steering Shaft Troubles NO STEERING HELP !!!!!
Rag-Joint/ aka Steering coupler
I have a 92 XLT, 4dr, power steering, 4.0 v6
My rag-joint/steering coupler was shredded, so i decided to buy a replacement. it has never been changed before so instead of it being bolted on with a bolt and nut, it was riveted with a decent size steel rod. So i used a dremel tool with a cutoff wheel to cut the bolts in half. Got them all cut in half, but they will not come out of the holes. I disconected the top of the rag joint which connected to the steering shaft right by the firewall. had to put it in a vise and hammer another bolt through to get the pieces out. let me tell you it was very hard to get the two pieces out having it right in front of me. now i still have 4 more halves to get out but they are on the lower piece, i do not know how to remove the adjustable shaft. does it come out? it is the shaft that moves in and out a little and has a rubber sleeve on it. My truck is out of commission right now as the steering is not connected. Please help if anyone knows what i can do. I am going in the morning to get a steel drill bit for the dremel and try to drill holes through the 4 remaining bolts, but if i drill small holes through the middle, i dont think it will make them come out any easier??? If there is any way i can get the shaft to come out of the box it goes into i could put it on the vise and hammer them out. Also the new steering coupler that i bought only came with 2 bolts??? need 4, so i bought another steering coupler kit. now i tried to fit the bolts and the new steering coupler together and the bolts dont even go all the way through, so i am going to get automotive quality bolts in the morning that are long enough and will just have to cut them back after i install them.
The biggest challenge right now is just removing the 4 remaining bolt halves.
Please HELP!!!!!!!!!!!!!
