need help,bleeding clutch,sprung leak | Ford Explorer Forums
kootenaykid
cranbrook b.c
89xlt
hi guys,i need some advice.just changed manual tranny,clutch,slave in a 89 ranger.try to bleed and sprung a leak.no fluid coming from bleeder at all.leaking from the quick disconect,not sure how to cure this problem.tried disconnecting and re conecting,but still leaking,what to do?any suggestions would be greatly apreciated.thanks
I'd say either the line is not seated right, or the connection is messed up. I would take it apart, and get a real good look at both ends of the qick disconnect, looking for damage. Is the white plastic ring stll there?
yes the ring is there and intact,it just seems like maybe the quick disconect is plugged or somthing,anyone know if theres any way to clean them or test to see if its plugged.and if you can clean them,what would you use on it.maybe gas or eether,not sure what to do,dont want to wreck it by cleaning it with somthing bad.any suggestions?
