Need Help for light bulbs | Ford Explorer Forums
speakenglish
ohio
92xlt
im looking for super bright white light bulbs for my 1st gen, what is the best or close to best i can get
super bright ones
type and/or price #
ill be ordering it from summit
To me, spoken English without punctuation and Capital letters, sounds very foreign.
Sylvania Silverstars are about as good as it gets for regular wattage bulbs. I dont know what Summit carries.
are all light bulbs universal? or do i need to get a speical type? what kind do i need?
bulbs are not universal, the 1992 ford explorer uses a 9004 bulb
are all 1st gen light bulbs the same?
low beams 80 watts
high beam 100 watts
or
low beam 45watts
high beam 65 watters
9004 bulbs are 45/65. All first gen. are the same. The higher wattage bulbs are available. However if you go 80/100 you would probably need a harness as the factory wiring & bulb connectors is not built for the extra wattage/heat and you would likely have a problem.
i have euro degsigns they are pretty bright
