Need help have multiple questions | Ford Explorer Forums
cmhaah06
CLOVIS, CA
91 XLT
Does Anyone Know Where I Can Find Any Of The Following: 5.13 Gears For The Dana 35? Six Inch Lift Springs? If I Can Not Find These Lift Springs, Does Anybody Have Any Experience With The 4" Rough Country Lift? Last But Not Least, On A Scale Of 1-10 How Difficult Is It To Install Either The Aussie Or Lockrite Locker? Oh Yeah This Is All For A 1991 Ex. Any Thoughts Or Advice Would Be Appreciated.
Search. Yukon makes D35 5.13s. Skyjacker offers 6" lifts and springs. DONT buy rough country, the brackets will punch a hole in your diff. Lunchbox lockers are easy to install. Remove the cross-pin, remove spiders, (carrier may require a tiny bit of clearencing with a dremel), install locker and springs, install cross pin. With gears as deep as 5.13s you will also have to grind the inside edge of the ring gear to allow the cross-pin to come out, it's a harmless practice as the spot that's affected isn't in the contact pattern. I'd give it a 3 out of 10.
i kno of 4/6/8in coils but only 4/5.5 in springs. altho you can do some kinda of frankensteining w/ your rear lift like ext. shackles or add-a-leaf or more arc. hanhs covered everything else i suppose
o and i suggest the superlift system i have the 4in installed and am very satisfied
