Dewayne
- June 21, 2005
- Charlotte, NC
- '97 Ford Explorer 4.0 2WD
Last weekend I put new spark plugs and wires on my 1997 Ford Explorer, 4.0, 2WD, SOHC. It ran great for a few days, then on Saturday it started missing badly and the Check Engine light came on. I took it to Autozone, and they said the codes were that it was missfiring on cylinders 2, 3, and 5.
They suggested I regap my plugs to .054 and try it again. I did, with no change. I then took the plug wires back and returned them for a new set. Not much of a change at all. I then tried a new coil pack, with no noticeable difference. It is still missing and running pretty rough.
Any ideas? Could it be the timing, or even the timing belt tensioner? The reason I am asking is because there was a squealing sound that I thought was my alternator for about a month prior to this. At about the same time I noticed the squealing had stopped was about the same day this happened. Any suggestions are appreciated. Thanks.
