Need help Still having problems | Page 2 | Ford Explorer Forums
Yer on your own here. I have nada clue that the speedo drive gears in the back of the 1354 have color codings. Snoop around and share your findings.
Will do. Hey by the way, There is another web-site that I visit and a friend of a friend said he had nearly the same problem with a Navaho (sp) His would not work at all though. He installed the gear, backwards the first time and tore up the driven gear. R/R it again and all is well.
Now just to get the right parts!!!!
Mark
So maybe that odd end IS a driven part somehow.
PROBLEM SOLVED!!!!!!
ACTUALLY SEVERAL SOLVED!!!!
1. speedo jumpy
2. rear TC seal leak
3.odometer reads correctly
4. vibration at 65 mph.
5. cruise control now controls!!!!
Here is the culprit:
http://www.explorerforum.com/data/503/DSCN6789.JPG
Thanks Glacier!!!!!!
The nut on the output yoke was not very tight.
I could get it loose with a 3/8" ratchet.
Ford dealership says this is to be 250 ft. lbs.
I replaced the part shown above, put my old speedo gear back in and a new output seal and had a friend come over to help give the ol' nut a tug. I did not have a torque wrench to go that high.
Thanks so much for those that lead me in this direction. I even argued with the Ford parts guy as to what I thought was wrong!!!!
Now on to other issues!!!!!!
I guess this is what happens when you buy used vehicles. I can not stand not to have something that is not working like it is supposed to.
Mark
Speedo is speady as a rock now!!!!
You said that you replaced this inner part. Your original was white like the speedo gear. Is that correct? Did you get a replacement in white to match your speedo gear that is on the VSS, or did you get the green one like in this picture? I'm wondering if they have to be a matched set?
Glad you got it fixed and you also added to our knowledge base here as well. Thank you.
This site will serve you well in the future as well... if you will forgive the commercial pitch, why not join us and become an elite member? You will help support the site and pay for the bandwidth.
Even if you don't we will help you in the future, as we do everybody. Elite or not.... we do not make a diferentiation. No one HAS to do anything to get help.... but consider it. It's the best $20 you may ever spend.
Glacier, I have been considering that.
To add to the useful info., The large nut takes a 30mm 12point socket and the 4 yoke bolts takes a 12 or 13mm 12 point end wrench. Those 4 bolts were extremely tight!!!! I was afraid that I was going to break the wrench. Use good wrenches when doing this. Also, it is not needed to take the TC rear half apart. Once the yoke is out, remove the large seal and the small shaft seal then put a small screwdrive in the speedo hole to move that piece out. Brooklyn,There was no color variation in the part that I removed and the part that I installed. I don't believe there is a different drive gear available.
When you reinstall everything, make sure the drive gear goes back in as the old one came out. Someone advised me on this but for the life of me, I could not tell a difference. Anyway slide the gear onto the output shaft then put your speedo gear in and tighten it down. You can get to the drive gear to check the mesh/operation then through the output hole. Install the rear seal. Make sure you install it the same way the old one came out. both sides of the seal look nearly the same. Put the yoke in, then install the little rubber seal onto the threaded area. I assume that this little seal is to prevent TC oil leakage around the splines of the output shaft.
Install washer and nut Ford says to run this nut down to 250 ft. lbs.
Install the drive shaft and the for bolts and tighten them down tight!! Check your and enjoy the test drive!!
To sum all this up, What I thought was a bad/bouncy speedo cable turned out to be the drive gear in the TC.
To check your speedo cable, remove the cable assembly from the TC and attach a reversable drill on the end of the speedo gear. Run your drill in reverse. My drive acheived 65 mph. and the speedometer was very steady eliminating all components from there to the cluster.
This is about a 2hr. job if all your tools are readily available first. Some will be able to do it faster some slower. I was not in a big hurry.
Hope this helps!!
Mark
Thanks for this information! If you took any pictures of it as you were doing it, you could make a how to thread. It would be very interesting, and helpful to anybody that is doing the same repair job.
